Cable Design
Disconnect
: Disconnect Branches
Disconnect Branches
To disconnect the cableway branch from its connection points, make sure that the cableway branch to be disconnected is highlighted as the CE in the Model Explorer. A Confirm window is displayed, prompting
Do you want to disconnect
. Click
Yes
to disconnect the selected cableway branch or click
No
to close the window and discard any inputs.
Disconnecting cableway branches means that cables will not be routed between the two branches.
