Cable Design User Guide
Copy Cabling Elements : Copy Cableway Elements
The Copy Cableway Element window has a common layout irrespective of the element selected to be copied. The only difference being the type of element to be copied, which populates parts of the Copy Cableway Element window.
The inputs required for Copy Cableway Elements window is dependent upon the element selected.
Make sure that the element to be copied is highlighted in the Model Explorer. With the element highlighted in the Model Explorer, select CE from the Copy Cableway Elements identify the element as the CE.
Defines the position of the copied element(s) at an offset to a selected element.
Alternatively, select Pick Offset, in the 3D view, a prompt to Please pick an Element to define offset (Snap) Snap: is displayed, click to identify the element.
Select Copy, the new element is created in the Model Explorer and a message is displayed to confirm the Copy was successful, click OK to close the message window.
