Cable Design
Modify
: Material Element
Material Element
Use the functionality to modify the currently selected material element. The
Modify Straight
window has the same common layout as the
Create Straight
with the exception for the modification functionality available from the window.
Properties of cable tray material element
Use to modify the cable tray material element’s properties.
Properties of cable tray template element
Use to modify the cable tray template element properties.
Copy with gap
Copies existing cabletray material element with gap.
Copy without gap
Copies existing cabletray material element without gap.
Update rules
Use the functionality to update template rules.
