The attributes entered in the Create Material window are automatically displayed in the
Modify Material window. To modify any of the attributes or dimensions, modify the attribute or dimension then click
Apply Changes to commit the changes or click
Discard Changes to discard any inputs.
Display the List of Cables window populated with all the cables associated with the current cableway branch.
Select from the Application Data. Application Data Areas and Elements are a new form of definition in the Design Database that are provided to assist Appware Applications to store model parts for copying and propagation within a design.
By default the Width and
Height are populated with the default cableway width and height. Different width and height dimensions can be entered if required.
Adds straight components to the whole cableway branch. Selecting the Do not cut check box prevents components being cut to fit the designated cable tray length.
Adds straight components to a selected segment. Selecting the Do not cut check box prevents components being cut to fit the segment length. A prompt to
Pick near the start of the segment to be dressed: is displayed.
The Preliminary Dressing (Considering Branch fill levels) window has the same common layout as the
Preliminary Dressing (User defined Dimensions) with the exception for the
Attributes part of the window.
Dresses the cableway branches using a selected template. The Dress using Templates window has the same common layout as the
Preliminary Dressing (User defined Dimensions) and Preliminary Dressing (Considering Branch fill levels) with the exception for the
Dimension Options and
Attributes parts of the window.
By default the Width is populated with the default cableway width; a different width dimension can be entered if required.
