Cable Design
Modify
: Junction Node
Junction Node
Use the functionality to modify the currently selected junction node element.The functionality is identical to that described in
Create a Junction Node
with the following exception.
The
Connect Cable Way Branches
pane is populated with all the cableway branches connected to the currently selected junction node.
A junction node can have as many connections as required or a single cable way branch can be connected to a single junction node.
Connect Graphical Selection
Connects the currently selected cableway branch in the 3D view to the junction node.
Disconnect Graphical Selection
Disconnects the currently selected cableway branch in the 3D view from the junction node.
Disconnect List Selection
Disconnects the currently selected cableway branch in the list from the junction node.
