Compare/Update User Guide
Options and Mapping : Link Database Administration including Global Projects
Use Manage Links to create a Link World in the new database, or to merge links from an old link world (prior to 12.1 link worlds resided in Design databases).
If using extract databases, then in PDMS DESIGN or Marine Outfitting, use the Extract Control form to select the existing CYMWRL and issue all changes. Repeat this step for all levels of extract database. The next step should then be carried out in the parent database.
In PDMS DESIGN or Marine Outfitting, use Manage Links to merge links from the Design database to a new Design Reference database (e.g. by drag and drop). Then click on the Design database and delete the old Links.
