The Accept column displays check boxes showing the current choice for how data will be updated.
The Matched column displays five possible options.
The Matched Against column lists the type of matching object in the target database.
The No. of Changes column lists how many attribute changes are available for update.
The Changed Attributes column displays a comma separated list of the attributes which have changes available for update.
The Attributes to be Updated column displays a comma separated list of the attributes which have changes available for update and which you have chosen to be updated.
The Logically Deleted column is displayed if logical deletion is available in the source or destination data. It displays True if the row contains a logically deleted object, otherwise False. Filter on this column to see only those rows containing logically deleted objects.
