The recommended alternative for matching of pipelines to pipes is by key attributes, to support the one to many relationships where one pipeline (schematic or engineering) may be modelled in 3D as multiple pipes. Key attribute matching uses a combination of several attribute values to identify matching 3D pipes for a source schematic or engineering line. For example, several pipes may be matched to a single line according to their values for line number, bore, pipe specification and duty. Key attribute matching must be setup using
Manage Groups.
