Compare/Update
Compare and Update Data
: Instrumentation, Electrical and P&ID Elements Matching
Instrumentation, Electrical and P&ID element matching uses the following criteria:
If element data from the target database (e.g. Schematics) had previously been imported into AVEVA Instrumentation, Electrical or P&ID, the Dabacon references will have been stored in there. If available these will be used as the first attempt to match.
If AVEVA Instrumentation, Electrical or P&ID data have previously been imported into the target database, and the integration UDA was available, the AVEVA Instrumentation, Electrical or P&ID database references will have been stored in the UDA. If available these will be used as the second attempt to match.
If the UDA is not available this step will be skipped. Refer to
Integration UDA Definition
for further information.
For Instrumentation, if the first two attempts have not generated a match, the third attempt will match on the default criteria of Tag or Loop as appropriate.
Instruments from AVEVA Instrumentation can be matched to Dabacon types Instrument, Equipment and Subequipment. This gives the capability for example to separate instruments into inline, offline mounted and offline non-mounted.
