Structural Design
SDNF Export/Import
SDNF Export/Import
AVEVA SDNF is the interface for the MODEL which allows the user to export and import files using the Structural steel Detailing Neutral File (SDNF) format. The SDNF format was originally defined by the Intergraph FrameWorks user community for the transfer of steel data. The format is in the public domain and is therefore available to be considered as a suitable means of transferring data between 3D steel detailing packages and Model.
The AVEVA SDNF interface uses a large proportion of the information transferable in SDNF format. Refer to
Technical Information
describing SDNF, its format and contents.
