Element and attribute mapping is controlled using the Compare/Update Configuration wizard. To create and edit configurations you must be a member of team CUADMIN. A single configuration defines the source and target types of objects that will be compared, and their attributes that will be mapped. The stages to define the configuration consist of:
Set Mode to Local if the source data is to be from a product installed on the same computer.
Set Mode to Service if the source data is to be from the AVEVA Integration Service. The window changes to show fields for
Server Name, Port and
Source. These should be set according to the Service configuration.
Select the Source database from the drop-down list. If the source is AVEVA Electrical, AVEVA Instrumentation or AVEVA P&ID, a Login button will appear. Click on this and log in to the source system.
Enter the Display Name that will be used for this source list in the Compare/Update window
Either click on Element Type and select the type of object in the source database or click on
Group and select one of the pre-defined source groups. Source groups will be available only in certain contexts such as Design Valves or Design Piping Specials where the group represents a combination of element types.
Select the Name Attribute that is to be used for name matching, and the
Unique Attribute that is to be used for internal ids.
In Element Type select the type of object in the target database.
Enter the Display Name that will be used in the Attribute Mapping screen.
Check Create Reverse Configuration to automatically create a configuration with source and target swapped (this option will be available only when both are Dabacon databases).
If advanced rules are required for this configuration, select a Project Configuration File (this will usually be the default filename for the project, for example: for Sample project this would be %SAMDFLTS%\ModelManagement\ProjectConfiguration.xml). Then select a
Rule Set and check
Use Advanced Rules.
Select the Restrict the Configuration to Admin Users only check box, if you want to test this configuration before publishing it for general use on the project.
Select the Make this Configuration available standalone check box to allow end users to be able to run it when it is not part of a group of configurations.
An optional Owner Expression can be entered. This will be evaluated against the appropriate source object during the Update Database process to determine the owner for an inserted object.
Click Add Mapping to add an empty attribute mapping row to the list. On the source side do one of the following:
Use the Allow Update check boxes to control which attributes will be compared only, and which may be updated.
Click Finish to complete and save the configuration.
Users who are members of team CUADMIN can set up advanced rules by clicking Configuration Explorer. This displays the
Project Configuration Explorer shared with Schematic 3D Integrator. There you can configure more elaborate rules for element matching and updating, in particular key attribute mapping to match multiple pipes against schematic or engineering pipelines. An example set of rules using key attributes for engineering to design matching is included in the out of the box ProjectConfiguration.xml file. Refer to the
Schematic 3D Integrator User Guide section on How to Configure Rules.
Select the required source database then click Add and enter the name of the new group. Select the
Restrict this Group to Admin Users only check box, to test it before making it available to the project.
The Edit menu provides
Cut,
Copy,
Paste and
Delete functions to move Link Worlds between databases. You can also drag and drop from one database to another to move or merge a Link World.
