Compare/Update User Guide
Options and Mapping : Grid Options
Column Setup allows you to choose which columns to display in the grid view and which order to display them. To display the Column Setup window, right-click on any column title and select Column Setup from the pop-up menu. The Column Setup dialogue contains the standard columns for the grid along with the attribute columns for the source type.
To display a Column Name in the grid view, select the required check box in the Visible column. Clearing a check box removes the Column Name from the grid view.
To change the position of a Column Name in the grid view, select the Column Name and click either the up or down arrows.
Click OK to update the grid view.
with filenames like SchAiInstruments.xml or SchAiLoops.xml
Right-clicking on any column title and selecting Settings, displays a settings sub-menu:
Enable Filtering allows you to display a filter row in the grid view. The filter row is used to filter the grid to show only certain records. Instant "on the fly" filtering is achieved by selecting the icon in the column field and selecting a value from the drop-down list.
Enable Column Summaries displays the icon in the No of Changes column. Clicking the icon displays the Select Summaries window.
You can check one or all the boxes and click OK to receive a count displayed at the end of the No of Changes column.
Clicking Refresh remove the count.
Enable Column Sort allows you to change the column order. Click and hold on the column title and drag the column either left or right into a new position. Two arrows are displayed to assist you in positioning the column.
Clicking Feedback Colours displays a sub-menu:
New Element Row Colour is used when an element is not matched and Compare/Update is able to insert it. The Not Matched Row Colour is used when an element is not matched and Compare/Update is not able to insert it.
Selecting Reset Default Feedback Row Colours, reverts the options back to their default colour settings.
Instrument Datasheet displays the AVEVA Instrumentation data sheet for the selected instrument.
Instrument Details displays the AVEVA Instrumentation window for the selected instrument.
Loop Details displays the AVEVA Instrumentation window for the selection loop.
