Compare/Update User Guide
Getting Started
In PARAGON, it is available from the Utilities in the Electrical Application only.
Click in the Source drop-down list to select from the available data sources.
Click Login and select the desired Instrumentation, Electrical or P&ID project from the list.
Click Select, and when prompted, enter the username and password for that project. Then select the desired source group. The available groups from AVEVA Instrumentation or Electrical depend on the host module and can include Instruments, Loops, Equipment, Cables and Cable Catalogue items. The available groups from AVEVA P&ID are the P&ID types Equipment, Instrument, Line, LineFitting, Nozzle and Valve.
If element filtering has not been set up, you may do this now. Click Filters to display the Filter window and define one or more filters. Refer to Filter for further information.
Or in Design select the menu option Compare Current Selection. A list of available configurations will be displayed.
